Abnormal Shutdown - Do I need to run any maintenance routines?
  • 703 Views
  • Last Post 05 December 2016
Sashi Rajamahendran posted this 05 December 2016
After an abnormal shutdown do I need to run any maintenace routines or does Pegasus look after itself?
Venkatachalam Settu posted this 05 December 2016
There is no need to run any maintenance task after an abnormal shutdown. If all the drives are healthy, then the volume will be mounted automatically to host machine when you power on the unit.
  • Sashi Rajamahendran
